1 Reply Latest reply on Feb 11, 2019 6:48 AM by Ryan Gerry
    Linear Pattern Configuration Propagation
    Ryan Gerry
      Hi All! I am working on a design table based assembly with multiple configurable components. There is one feature that is used a variable number of times and as such, I have used a linear pattern and have linked the count to the design table. I have set the linear pattern property to "Use same configuration as pattern seed component" and selected "all configurations". My problem is, these two property settings appear to stay until I rebuild an assembly with quantity change, once the quantity is changed they seem to reset to a specific configuration on a per configuration basis.
      Am I setting my variables in correctly?
      Does anyone have a different approach / work around ideas?
