Can't select successful when I use "ModelDoc2.SelectByRay" in assembly environment
Question asked by Win Lai on Nov 16, 2018
Latest reply on Dec 12, 2018 by Win Lai
dear everybody,
I can use "ModelDoc2.SelectByRay" correctly in a Part document. But when I use the same code in Assemlby document ,it is unsuccessful.
Demo file have been uploaded.I am looking forward to someone who can tell me why.
thank you very much!
'Here is the code in vba====================================
Option Explicit
    Dim selParams(6) As Double
    Dim varSelParams As Variant
    Set swModel = swApp.ActiveDoc
    ' Selection ray definitions
    ' Origin X location
    selParams(0) = 0#
    ' Origin Y location
    selParams(1) = 0#
    ' Origin Z location
    selParams(2) = 1#
    ' Direction X component
    selParams(3) = 0#
    ' Direction Y component
    selParams(4) = 0#
    ' Direction Z component
    selParams(5) = 1#
    ' Intersection radius
    selParams(6) = 0.01
    'try "selParams(6)=0.01" in part1 =====>then successful
    'try "selParams(6)=0.009" in part1 =====>then unsuccessful(it is correctly, because the minimum distance from the part to the origin is"0.01")
    'try "selParams(6)=1" in part1 =====>then successful
    ‘The coordinate system of the part and assembly is completely coincident
    'try "selParams(6)=0.01" in Assem1 =====>then unsuccessful
    'try "selParams(6)=1" in Assem1 =====>then unsuccessful
    varSelParams = selParams
    Dim Status As Boolean
    Status = swModel.SelectByRay((varSelParams), swSelectType_e.swSelEDGES)
    Debug.Print ("Selection successful: " & Status)
