I made this Slot and Tab by means of showing and hiding the parts. I wish to know whether there is any other method to make this. I mean method that can distinguish overlapping faces and edges.
I tried with “Select Others” but it didn’t work.
Hi Maha,
I'm not really sure I understand what you are trying to achieve but do you mean like interference detection?
Dave.
What Maha is asking, is the selection of the required geometry when creating the Tab & Slot feature.
When creating the Tab & Slot feature, especially in the case of a mitred angle as shown above, you have to select an edge on one body, select a face on the other body & then select a face on the original body. In this case you have to hide one body to select an edge, then show it, then hide the other body to select a face, then show it, then hide first body to select a face & then show. Maha is asking if there is an easier way other than right clicking in the feature tree on a body & selecting show/hide. The Tab key doesn't work as it does in assemblies or multibody parts as it just skips between the boxes in the Tab & Slot feature.
I have attached a video of my workflow which seems to work.
