I have placed this in Modelling and Assemblies, despite the reference to PDM in the title, because I think the problem lies in my model, not in PDM.
Unless you know different...
I created a part in SW, and gave it all the usual Custom Properties
I checked it into PDM and looked at its data card:
Imagine my surprise when I observed that it weighed 4 tonnes!
I then looked at the Mass Properties in SW:
The sums don't seem to add up - 4908 cubic mm, density 0.01 g/cubic mm - that makes the reported mass in PDM seem very sensible.
However, SW is reporting a mass of 38.78g.
I immediately checked and, no, the mass properties are not overridden.
I then did another quick check and, since the diameter is 25mm and the thickness is 10mm, that seems to me as if the reported volume is correct.
The material is set to 304 stainless, which would make the density 7900kg/cubic m, or 0.079g/ cubic mm.
That should make the actual mass 785.4 x 0.079 = 38.78g, not 4908.7.
What's going on?
Where is the density value of 0.01 grams per cubic millimetre coming from?
Can SW mass properties ever be trusted?
File attached, for completeness.
SW2018, SP4
PDM Standard
Cheers,
John
It appears you may have multiple issues
the Weight on the Data card matches the Volume in the Mass properties, have you verified that the Datacard is pointing to Mass not Volume?
