This is my first question, I hope to post it in the right section.
I have an assebly driven by a part of just sketchs (I'll call this part: master), so each part of the assembly refer to one or more sketchs of "master".
The master's sketchs are driven by a design table in order to update all parts of assembly in once.... (more or less...)
I wonder if there is a way to send to the parts (through design table) also text data (example: customer name, number of commitment and so on) in order to store to the properties of the parts and see them on drawing table.
Thank in advance for your attention.
M.
Hi Mic, after creating your DT, add the custom properties you need in the custom property manager in the 'Configuration Specific' tab:
Then, 'Edit Table' and you'll be asked to add the new properties in:
Select them and you've done.
Now you can pass them to the drawing.
