3DVIA Composer: Tip of the day
Have you noticed that when you create balloons in 3DVIA Composer, invariably you get inconsistent diameters depending on # of characters in Bom-ID. (see balloon-1)
Solution:
You can create consistent size balloons (see Balloon-2) by changing the Document properties (under Edit menu). (see Balloon-3).
To apply this setting to all documents, change the same settings in "Default Document Properties" (under settings menu).
Best Regards
Solution:
Best Regards
