Hi, I'm trying to get every single combination between the parts inside my assembly using the configuration on each parts (8 for the top, 2 for the side left, 2 for the side right, 2 for the modesty panel and 4 for the Assembly. Total of 256 possible combinations) and then save the BOM on a csv file from the Assembly level not part level and if is possible the Assembly with the actual configuration, I'm trying to build a script on VB on .NET, I have been trying to use recursion but without luck.
If anyone has any Idea how to do this I'll appreciate your help.
Thanks in advance
I included the Assembly Model
Do you want to generate separate assembly for each combination? Take a look at this macro: Components Configurations Permutation
