Hi
I'm just trying to set up routing here for electrical routes (only) and after much struggling with the odd workflow I think I understand it all and am fairly happy. (Though I think it could be improved) Anyway, I have a question I'm hoping someone can answer.
I use a lot of standard IDC cables and I wanted to set up a standard library of them, I've done this, but have some queries:
1. when I insert a standard cable, SW assigns a filename based on the part number. Obviously this cable could be used in many places all of the same length, but the wire part file would always be different depending on its routing. It seems that this will cause many problems when I try to check the assembly into PDMWorks, as it will try and overwrite a previous wire part with the new one? Am I missing something here?
2. If I insert a standard cable and it then tells me the wire isn't long enough, is there an easy way to go back to the standard cables list and select a longer one? or do I need to delete the route and insert a new one (or make the length not fixed, but this could lead to filename problems as the filename will be the shorter part number)
3. Also, not related to standard cables.. Sometimes I get a 'from-to has been updated' warning msg and prompted to re-import even though it hasn't changed. anyone know why it would do this?
2009 2.1
Rich
2009 2.1
Rich
Standard cables/tubes and PDM is a problem. We have looked at this with the PDM guys and as of this moment we don't have a full solution.
I have not tried it, but in theory now we use virtual components for route assemblies this problem may be easier to deal with (2009). The Std cable is part of its parent assembly so isn't checked into PDM directly.
Fromto has been updated warning. We now record the name of the fromto file in the assembly, along with its date. Periodically we then check that file to see if it's date has changed. If it has, we set this warning so that you know the file has changed and the route needs to be updated. If you (or someone else) open the file just to read it, than exit, it will change the date so you'll receive the warning.
The warning should only occur if the files last edit date has changed.
Please let me know if you feel it is not working as it should.
Cheers
Andy
