Attached is a file I created that uses configurations for AISC channels.
I'm wondering if the same approach could be used to configure sheet metal once I get upgraded to SW2018 from SW2017
I think this becomes possible in 2018 because I believe bend radius is able to be a global variable.
My goal is to make everything about sheet metal a single choice:
Bend radius
Thickness
Material (weight, look (including floor plate), proper values for possible FEA)
Custom field for material number
I can live with the K factor always being 0.33 or manually edited when needed.
This would be a huge upgrade from my current best solution of using:
Gauge table
Material choice
Manually entry of a material number
With my current method, the chance of making a mistake is huge because all three items always have to be edited if a part changes from say 12 gauge carbon to 12 gauge stainless.
The only cost would be setting up the one file, and that all sheet metal designs would have to start using that one file.
I'm sure it can be done via design table/configuration publisher if you want configuration i the same file. And in case you want new file every time, then look no where other than DriveWorksXpress (a free automation add-in inside SW)
