Howdy All,
Currently I've been tasked with converting all our solidworks drawings to pdf's so i can hyperlink them to our excel standards index (we're making pdf's so people without solidworks can reference). Should be an easy task for task scheduler to export all dwg's within the folder to pdfs for this purpose. Now this is my first time using task scheduler so i don't know all the nitty gritty details, but it seems like it should be a fairly cut and dry situation. Everytime i run it, though, it shows this error:
This was a test run to see if it would work. Says "Failed to run SOLIDWORKS" in the status bar for each dwg ( there are 4).
And suggestions to why this would happen?
Is this maybe a windows 10 issue?
#TASK is a program you can download that works with SW to do all sort of things, very similar to task scheduler.
https://centralinnovation.com/solidworks/extensions/task-by-central-innovation/
