how to add a rendermaterial to a specific display state
Question asked by Veit Wollinger on Nov 8, 2018
why does this Code not work?
want to add a rendermaterial to a specific Display state (Display state name ="Innen")
'Written by Keith Rice
'CADSharp LLC
'www.cadsharp.com
Option Explicit
Const APPEARANCE_PATH As String = _
    "P:\Konfigurator\SW\Konfigurator_DIN_links\Erscheinungsbilder\fs3005.p2m"
    Dim swObj As Object
    Dim swRenderMat As SldWorks.RenderMaterial
    Set swModel = swApp.ActiveDoc
    Set swObj = swSelMgr.GetSelectedObject6(1, -1)
    If swModel.GetType = swDocPART Then
        If swObj Is Nothing Then Set swObj = swModel
    ElseIf swModel.GetType = swDocASSEMBLY Then
        Dim lngInfo As Long
        Set swAssy = swModel
        If TypeOf swObj Is SldWorks.Face2 Or _
            TypeOf swObj Is SldWorks.Feature Or _
            TypeOf swObj Is SldWorks.Body2 Then
            Set swComp = swSelMgr.GetSelectedObjectsComponent3(1, -1)
            swComp.Select4 False, Nothing, False
            swAssy.EditPart2 False, True, lngInfo
            If lngInfo = -1 Then
                swApp.SendMsgToUser "Failed to edit component."
                Exit Sub
    Else
        Exit Sub
    Set swRenderMat = swModel.Extension.CreateRenderMaterial(APPEARANCE_PATH)
    If swRenderMat.AddEntity(swObj) = False Then
        swApp.SendMsgToUser "Failed to add entity."
        Exit Sub
    If swModel.Extension.AddDisplayStateSpecificRenderMaterial( _
        swRenderMat, swSpecifyDisplayState, "Innen", Empty, Empty) = False Then
        swApp.SendMsgToUser "Failed to add appearance."
        Exit Sub
    swModel.EditRebuild3
    If Not swComp Is Nothing Then
        swAssy.EditAssembly
