How to generate BOM with required material information?
Question asked by Nandika Sirinuwan on Nov 7, 2018
Latest reply on Nov 7, 2018 by Deepak Gupta
Hello Friends,
I have designed an assembly using more than 10 parts, The assembly has previously designed assembly also.(2 assembly levels).
I want to generate a BOM for  the top level assembly's each parts.
I want to add material name, material volume, surface area,maximum width and height (that means if my part is cylinder that has 10mm diameter and 20mm height 5mm diameter hollow , BOM should have needed material width and height for machining the cylinder)
Is this possible to generate this information using Solidworks? If yes, How can I  do it?
Thank in advance
