Can you upload the parts also, then I can make the animation
for you. If you want to try, use distance mates and then change the
values in the Motion study.
Thank you very much & appreciate you taking the time to teach
me
I am still trying to understand your steps of animating the
assembly
By the way, if I have 2 springs behind the slide
How do I show the springs compress as the slide move backward ?
Attached is the file with 2 springs
Appreciate you again to show me the pdf fro showing step by step
how you do it
Did you receive my file with 2 springs ?
Are you busy that you have no time to show me the springs compress
Hope you can help
You need to model the spring in-context with the moving part,
so the spring length will follow the changes of mate distance.
You also can use dimension linking or simple formula to link the
spring length to mater distance.
You can upload any types of files. Picture files can be directly attached. For any other file type you need to zip them before attaching.
Check this link for How to attach file
