So I know next to nothing about macros.
I'm attempting to do a macro that does a bunch of things and track the time of how long it takes to do those things. I started a macro, did a bunch of things and saved the macro. I added some lines I found to record time and report it.
I run the macro and it appears to run. First action is to open an assembly, it does that. However once it opens up it does not show the rest of the actions on the screen. I'd believe that I need those things to be shown on screen in order to get the real time that I'm looking for.
It appears to run thru the entire macro and successfully reports the time it takes to do it...which I know to be significantly slower than what it takes to do when it's shown on the screen.
My questions would be.
1) Is there a way to show this stuff on the screen
2) Is it possible that despite showing up in the macro that the actions I took are not actually happening for some reason?
Based on the fact that you recorded the macro, my confidence that the macro is not doing everything is nearly indistinguishable from 100%. Can you post the code?
