Changed global variable defined sketch doesn't update second converted sketch
Question asked by David Bogdal on Nov 1, 2018
Latest reply on Nov 20, 2018 by Rubén Rodolfo Balderrama
FYI, I'm in SW 2016 sp 4 and do not have access to test other versions.
In a new Solidworks part, I create a 2D sketch on the front plane of the outline profile of a bottle. All the key dimensions of this shape are made referencing a single global variable (A). Then I create a second sketch on this same plane and use Convert Entities to convert this outline profile. In this sketch I use offset entities to add a wall thickness and add some tangent or fillet sketch lines to smoorth out parts of the design. I then use this second sketch to revolve and create the physical bottle. I create a third sketch and use convert entities to reference the second sketch's offset line, I fill out this sketch (so that it can revolve), and then revolve it. This third sketch revolved gives me the bottle's internal volume.
I now need to adjust the gobal variable (A) so that the bottle can scale up so that I can increase the internal volume to hit my target volume. My problem is, that when I change global variable (A), the first sketch updates fine, but the second one that references the first (through convert entities) does not update. The error on the second sketch reads:
Warning: The sketch has not been updated being solving it would result in invalid geometry (such as zero-lenght line). Consider:
- Deleting the invalid geometry.
- Changing relations or dimensions to eliminate the invalid geometry.
How do I debug what's causing this?
