I tried to save a fairly large assembly as STL and got this message:
Due to the lack of available virtual memory your STL request has been terminated.
Please increase ypur STL deviation and/or angular tolerance or increase the available memory for your system.
At no time in the run-up to this error did the memory used increase beyond about 8.5GB, in a machine with 16GB fitted.
I imagine this error message may not mean what it says, but what does it mean?
How can I STL this file?
SW2018, SP4
Windows 10 Pro
John
because of the memory consumption i would say, it's a lack of available memory - as the message says.
So try out to save in a lower resolution. You'll find the "Option" button, when saving as STL.
And the other thing, i would recommend, is to rise the swap file size in Windows.
