Configure Feature is giving a message like this. Even though I uninstalled SWX2018 and installed 2019. How to get rid of this?
You can edit them manually.
I can see you still have path pointing to 2017: Costing Template.
I believe the one you need to change now is: Custom Property Files.
You can change all 20xx to 2019.
Make sure there is a folder.
If you or other changed files in older version, you may need to make the change in 2019 also.
Don't try to change Search Paths. They are from Windows indexing. You can't change them.
Maha Nadarasa wrote:
You can see after uninstalling SWX 2018 remnant folders are still there. Is there any software to get rid of all SWX 2018 folders and install 2019 to get rid of these type of issues?
I haven't used it, and it's several years old, but https://www.javelin-tech.com/blog/2013/08/complete-uninstall-of-solidworks/ might work.
