Hi! I'm a beginner with Solidworks Electrical, so type slow please.
Under Title Blocks Manager I created a new title block with 20 rows and under the title block properties I set "number of first row" to 1. However, on my drawings the first row is number 4, and each row increments by either 4 or 5. Any ideas on what I did wrong?
Patrick, there are calculations you set up to tell SWE the spacing of your ROW counters. Make sure you have your ROW attribute positioned where you want the numbering to start, and set the position, and then the ROW height to match. What is happening here is it "calculates" the ROW in the background, and punches that calculation through where the ROW attribute is located, so if your background math doesn't match up to your ROW attribute spacing, you'll get various numbers that don't line up.
