8 Replies Latest reply on Oct 30, 2018 12:48 PM by Kevin Chandler
    how does one add material not found in the material library?
    Stacey Boudreaux
      I needed a material not found in the standard on-board material library with solidworks 2018 premium w/ subscription.  one option is the solidworks materials web portal, which is not available to me.  so question is how does one add material to the library.  I assume if it can be manually, one would need all the engineering data for the material as to provide accurate results from studies and analysis.
