OHOmar Hernández30/10/2018
So I need to model a spiral bevel gear and can not find much information regarding tooth design for a spiral bevel gear. Can someone please generate a part using Geartrax to help me out? I would like the gear and pinion. Here is the gear info:
Gleason spiral bevel gear
Shaft angle: 90 deg
module: 8
face width 55 (actual length is shorter, but i will cut the model)
spiral angle 35 deg
num teeth pinion 12
num teeth gear 34
