27 Replies Latest reply on Mar 2, 2019 11:54 AM by Deepak Gupta
    Macro to reset property tab
    Nicolò Bernareggi
      Hi evrybody,
      i'm looking for a way to create a macro (or any other system) that reset alla the field of the property tab that i've create to fill the field of my personalized titole block.
      i hope you would understand my request! my english is so bad!
      Thanks in advance!
        • Re: Macro to reset property tab
          Fifi Riri
          This macro will delete all Custom properties including the ones created by property tab. Modify it as needed.
          Option Explicit
              Set swModel = swApp.ActiveDoc
              Dim vConf As Variant
              Dim i As Integer
              ClearCustPrps ""
              For Each vConf In swModel.GetConfigurationNames
                  ClearCustPrps CStr(vConf)
              Next
          Sub ClearCustPrps(conf As String)
              Dim swCustPropMgr As SldWorks.CustomPropertyManager
              Dim vPropNames As Variant
              Dim vPropName As Variant
              Set swCustPropMgr = swModel.Extension.CustomPropertyManager(conf)
              If Not swCustPropMgr Is Nothing Then
                  swCustPropMgr.GetAll vPropNames, Empty, Empty
                  If Not IsEmpty(vPropNames) Then
                      For Each vPropName In vPropNames
                          swCustPropMgr.Delete vPropName
                      Next
              Nicolò Bernareggi
              thank you! but if i paste the code inside a new macro nothing happend!!!
              where i'm wrong??
                  Fifi Riri
                  The model needs to be rebuild.
                  I modified the above macro with a rebuild function:
                  Option Explicit
                      Dim i As Integer
                      ClearCustPrps ""
                      Next
                      swModel.EditRebuild3
                              Next
                Mithilesh Kapre
                Looks like you want to empty all fields in the Custom Property Pane (under task pane) as below.
                I don't see a way to do that
                  Amen Allah Jlili
                  This is possible but definitely is not worth the investment (Through Windows API). The only thing you can set from the API that is Property Tab Builder related is the template according to my knowledge.
                    Nicolò Bernareggi
                    I'm sorry if i'm disappeared but the question has fall down in office...but now i was thinking if isn't possible delete the custom property of the drawing (made by property tab builder) if the solution can be the copy of the property from an empty file?
                    What do you think?
                    Is it always difficult to realize?
                      Amen Allah Jlili
                      What's the error message. Are you sure you have an active document?
                          Nicolò Bernareggi
                          Yes i have the drawing opened (.slddrw) with the model (.sldprt) inside.
                          this is the error:
                              Amen Allah Jlili
                              That explains it. The macro is trying to get the configuration names to delete all properties in all configurations, meanwhile, your active document is a drawing which doesn't have configurations.
                              Try this:
                              Option Explicit
                                  Dim vConf
                                  ClearCustPrps ""
                                  If swModel.GetType = SwConst.swDocumentTypes_e.swDocASSEMBLY Or swModel.GetType = SwConst.swDocumentTypes_e.swDocPART Then
                                      Next
                                          Next
                                  Nicolò Bernareggi
                                  no way...launched don't give me back errors but nothing happen at the property maded by property tab builder
                                      Amen Allah Jlili
                                      Hm. Sorry I was just pointing why the posted macro didn't work. I don't think that is possible to do what you want in the property tab.
                                      Best,
                                      Amen Jlili
                                      SOLIDWORKS API / PDM API Developer
                                      www.cadsharp.com
                                        Deepak Gupta
                                        Are you looking to delete properties from model or drawing?
                                            Nicolò Bernareggi
                                            sorry i thought that i already had replied you...yes...i'm trying to reset the custom property in a drawing
                                                Fifi Riri
                                                It needs to be rebuild for the Tab builder to update
                                                Option Explicit
                                                    Dim i As Integer
                                                    ClearCustPrps ""
                                                        Next
                                                            Next
                                                    Nicolò Bernareggi
                                                    great!! it works! thank you!
                                                    but it works only for the fields that are "open" look at the image in the post of Mithilesh Kapre posted on 30-ott-2018 20.49...for example it works on Project Name, Folder Name, Description, Part Number...but don't resets the fileds with a "dropdown menu" like Designer, Detailed by and also te date...
                                                    Is it possible to work also on these?
                                                        Deepak Gupta
                                                        Codes works for me i.e. they delete all properties. If I set the codes to blank out the values but keep the property name, that works as well expect in case the property type is a date or yes/no as these can't be reset unless you change the property type.
                                                            Nicolò Bernareggi
                                                            so, if i don't change the property type, it isn't possible delete the fields?
                                                            with "change the property type" you mean for example to change the dropdown menu whit a box where i can type?
                                                            Thanks!
        Fifi Riri
        "change the property type" means changing the custom property type itself. (Date to string)
        But instead you could change the fields in the Tab Builder for simple Text box, that should work.
        Nicolò Bernareggi
        it works if I use the "text box"...but I prefer to leave it like a date or a "dropdown menu"!
        Deepak Gupta
        Try these codes (these are not working with Yes/No type)
        Option Explicit
        Dim i As Integer
        ClearCustPrps ""
        Next
        Dim vPropTypes As Variant
        Dim j As Long
        Dim custPropType As Long
        swCustPropMgr.GetAll vPropNames, vPropTypes, Empty
        For j = 0 To swCustPropMgr.Count - 1
        custPropType = swCustPropMgr.GetType2(vPropNames(j))
        swCustPropMgr.Delete vPropNames(j)
        swCustPropMgr.Add2 vPropNames(j), custPropType, Empty
        Next j
                                                  Cad Admin
                                                  In some cases, i find it easier to delete the custom property itself, then re-add it back in the same macro.
