What is the Solidworks equivalent of Inventors projection curve
Question asked by Ken Jones on Oct 26, 2018
Latest reply on Oct 26, 2018 by Krzysztof Wojcik
Hello newer to solid works coming from inventor. In inventor you can use the projection curve tool to create a complex 3D sketch that is a combination of 2 sketched splines.
I would sketch a spline on the right plane in sketch 1 and then another spline on the top plane in sketch 2 then start a 3D sketch and use the projection curve tool to create a new 3D spline that was a mix of the 2 open splines. I use this 3d spline to sweep a wire. Is there a solid works tool that does this?
