Hey
If I import a step-Iges or parasolid from another program and transform it to sheet metal using insert bends, it folds out very well, the problem is that there are almost never used the right inner radie for our bending tools. I have tried to edit the inner radie, but I cant seem to find a easy solution in the edit "process bends". Anyone have a good idea, I belive several have the same issue out there.
Thank for the response
Then add the radius fillets you would like to have for your tooling.
Then add your sheet metal feature and process the bends.
Cheers,
