I need to build a new CAD workstation for my boss. We using
Solidworks 2009, and have several very large assemblies that we
need to work with. I am looking for you suggestions and critiques
on the system I have came up with. I realize some of the components
I have picked out are new technology and therefore, we will pay a
premium. I am looking to build a screaming and very stable system
for him, money is (as it always is) an issue - but we have spent
about 4k on workstations in the past, so that is my target.
What im looking at:
GPU - Intel Core i7 Extreme Edition 965 Nehalem 3.2GHz LGA 1366 130W Quad-Core Processor
RAM - CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory
PSU - CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
VIDEO CARD - (2X - SLI CONFIGURED) PNY VCQFX3700-PCIE-PB Quadro FX3700 512MB 256-bit GDDR3 PCI Express 2.0 x16 SLI Supported Workstation Video Card
HARD DRIVE - (2X - RAID 0 CONFIGURED) Intel® X25-E Extreme High Performance Solid State Disk (SSD) - 32GB, SLC flash technology, 2.5 form factor, SATA (3.0Gb/s)
MOTHERBOARD - ASUS P6T Deluxe LGA 1366 Intel X58 ATX Intel Motherboard
CASE - Antec Three Hundred Black Steel ATX Mid Tower Computer Case
I realize I am missing a few components, but the majority is here.
Thoughts, suggestions?
What im looking at:
However if you want you could set up SLI MultiView.
See definitions below
SLI Frame Rendering - two cards to one monitor. Requires the SLI connector. SW does not take advantage of SLI Frame Rendering.
SLI Multiview - two cards/two monitors, each card running their own monitor. Does not require SLI connector and is supported on the FX570 and all the current Nvidia offerings.
I would also go with WD VelociRaptors in a RAID 0 set-up instead. I am still not convinced on the speed or reliability of SSD. Lots of money for the performance increase, if any. The WD's are well proven for speed and reliability.
If you are saving your files to the network way bother with the SSD drives, other then being able to launch Windows and SW quickly. Those are not likely your slow downs during the day.
I am very happy with my Core i7 system. It is very fast and a pleasure to work with.
Cheers,
