I created this weldment part using Solid Works
2016 sp2.0, and I have problem relate the duplicate balloons, please I would
like to know if there is a method that I could control this but in parametrical
way, a settings something relate the cut list table, similar with the settings
from assembly and BOM table where we could control the balloons duplicate,
thank you I really appreciate. Please see the ppt from attach. Best.
Sorin,
Thank you for the parasolid; answered many questions. Items 1 & 9 the 0.5625 diameter holes in item 1. For items 2 & 7 they are opposite hands. For items 5 & 8 even though they are the same length, width and thickness the 0.5625 diameter holes are in different locations by 0.00034641. Granted not much but enough for SolidWorks to see them as different items. If those holes are put in after the items are welded then the holes should be suppressed in the <As Welde> configuration and the bodies will most likely combine the way you want them to. I hope this helps.
