0 Replies Latest reply on Oct 23, 2018 7:40 AM by Jeff Ausfeld
    Surface registration
    Jeff Ausfeld
      When using copy surfaces or composite curves and I make a change up design tree such as moving the original surface or change a length or scale then these surfaces and/or curves effectively are lost and need to be either be recreated from scratch or they get shifted elsewhere in the model and need to be fixed.  This is especially evident in a surface wrap.  The shift to a different part of the model is the most telling part of this bug, it means some sort of originating feature number is being recalculated in error.  For example, if I had changed the originating sketch or dependent sketch in terms of number of lines, or something to that effect, this decoupling would be expected but just changing a line length but not deleting the original line should not cause this decoupling effect.
