So I'm Trying to design an air inlet. I created tapered extrusions to link the inner surface (a revolution) and the outer surface (a loft). What I'm trying to do it do a cut loft that will remove the excess material from the outer part of my piece. I'm trying to remove the triangles outside of the outer piece.
Hi Logan,
You haven't attached your model here, so this is just guess work BUT, if your triangular extrusions are extruded from the centre of the model then you could just edit the extrusion so that it is "Up To Surface" and then select the inside surface of your cone. That way the extrusions will not protrude externally and you won't need any trimming or lofted cut. Of course, this is all dependent on your where your sketch planes are (hopefully centred).
Dave.
