6 Replies Latest reply on Feb 12, 2019 2:14 PM by Michael Corriveau-Cote
    Apply Material (Delegate)
      I've been reading alot about the avalaible delegates with SldWorks :
      2017 SOLIDWORKS API Help - SolidWorks.Interop.sldworks Namespace
      I can't seem to find a way for my addin to know when a material is applied to the part. For now, i am using the SaveFileNotify but it really isn't optimal.
      Anyone has an idea?
      Here's the my code to transfert Material Custom Properties to the Configuration Specific Custom Properties. Starting Function is TransfererProprietePersonalisee_Material :
          ''' <summary>
          ''' </summary>
          Private Class Classification
              Public Property Name As String = ""
              Public Property Materials As New List(Of Material)
              Public Sub New()
              Public Sub New(_Name As String)
                  Name = _Name
          End Class
          ''' <summary>
          ''' </summary>
          Private Class Material
              Public Property CustomProperties As New List(Of CustomProperty)
              Public Sub New()
                  Name = _Name
          End Class
          ''' <summary>
          ''' </summary>
          Private Class CustomProperty
              Public Property Value As String
              Public Sub New()
              Public Sub New(_NomPropriete As String)
                  Name = _NomPropriete
              Public Sub New(_NomPropriete As String, _Valeur As String)
                  Value = _Valeur
          End Class
          ''' <summary>
          ''' Transfert les proprietes personalisees du materaux choisi vers file->properties->custom
          ''' </summary>
          Public Sub TransfererProprietePersonalisee_Material(swApp As sldworks.SldWorks)
              'ugogo
              Dim ListClassifications As List(Of Classification) = ParseXMLCustomMaterial()
              Dim swDoc As sldworks.ModelDoc2 = swApp.ActiveDoc
              Dim swPartDoc As sldworks.PartDoc = swDoc
              'Dim OriginalConfig As String = swDoc.ConfigurationManager.ActiveConfiguration.Name
              For Each Configuration As String In swDoc.GetConfigurationNames
                  Dim MaterialDbInfo As String = ""
                  Dim Material As String = swPartDoc.GetMaterialPropertyName2(Configuration, MaterialDbInfo)
                  DeleteMaterialCustomProperties(swDoc, Configuration, ListClassifications)
                  For Each prop As CustomProperty In AddMaterialPropertiesToCustom(Material, ListClassifications)
                      swDoc.AddCustomInfo3(Configuration, prop.Name.ToString, swCustomInfoType_e.swCustomInfoText, prop.Value.ToString)
                  Next
              Next
              'swDoc.ShowConfiguration2(OriginalConfig)
          Private Function GetMaterial(swDoc As sldworks.ModelDoc2) As String
              Dim SwFeat As sldworks.Feature = swDoc.FirstFeature()
              'Fait le tour du feature tree (gauche) pour trouver le matériau sélectionner
              Do While Not SwFeat Is Nothing
                  If SwFeat.GetTypeName2.ToUpper = "MATERIALFOLDER" Then
                      Return SwFeat.Name
                  SwFeat = SwFeat.GetNextFeature
              Loop
          End Function
          Private Function AddMaterialPropertiesToCustom(Material As String, ListClassifications As List(Of Classification)) As List(Of CustomProperty)
              Dim ReturnList As New List(Of CustomProperty)
              For Each Classif As Classification In ListClassifications
                  For Each Mat As Material In Classif.Materials.Where(Function(x) x.Name = Material)
                      ReturnList.AddRange(Mat.CustomProperties)
                  Next
              Next
              Return ReturnList
          End Function
          ''' <summary>
          ''' </summary>
          Private Function DeleteMaterialCustomProperties(swDoc As sldworks.ModelDoc2, Configuration As String, ListClassifications As List(Of Classification)) As List(Of CustomProperty)
              Dim PropertyNames As String() = swDoc.GetCustomInfoNames2(Configuration)
                  For i As Integer = 0 To PropertyNames.Count - 1
                  If IsMaterialCustomProp(PropertyNames(i), ListClassifications) Then
                      swDoc.DeleteCustomInfo2(Configuration, PropertyNames(i))
                  Else
                          'Faire une liste de ce qui est déjà traité?
                  'Else
                  '    'ReturnList.Add(New CustomProperty(PropertyNames(i), swDoc.GetCustomInfoValue(Configuration, PropertyNames(i))))
                  '    ReturnList.Add(New CustomProperty(PropertyNames(i)))
                  'End If
              Next
              Return ReturnList
          End Function
          Private Function IsMaterialCustomProp(PropertyName As String, ListClassifications As List(Of Classification)) As Boolean
                      If Mat.CustomProperties.Where(Function(x) x.Name = PropertyName).Count Then Return True
                  Next
              Next
              Return False
          End Function
          ''' <summary>
          ''' '''Va chercher toute les propriete custom des materiaux custom dans la librairie du poste et sur le réseau
          ''' </summary>
          ''' <returns></returns>
          Private Function ParseXMLCustomMaterial() As List(Of Classification)
              'check for ING library of custom mats
              Dim ReturnList As New List(Of Classification)
              Dim PathCustomMatING As String = MyConfig.ConfigApplications.PathCustomMatING
              Dim fichierArray() As String = Directory.GetFiles(PathCustomMatING)
              Dim PathXML As New List(Of String)
              If fichierArray.Count = 0 Then
                  MsgBox("Impossible d'accèder au répertoire de matériaux : " + vbCr + PathCustomMatING)
              For Each fichier As String In fichierArray
                  If Path.GetExtension(fichier) = ".sldmat" Then PathXML.Add(fichier)
              Next
              'check for local custommatfile xml (tries french then english)
              If File.Exists(MyConfig.ConfigApplications.PathCustomsldmatlocalfrench) Then
                  PathXML.Add(MyConfig.ConfigApplications.PathCustomsldmatlocalfrench)
              Else
                  If File.Exists(MyConfig.ConfigApplications.PathCustomsldmatlocalenglish) Then
                      PathXML.Add(MyConfig.ConfigApplications.PathCustomsldmatlocalenglish)
                  Else
                      MsgBox("Le Fichier de matériaux personnalisés local est introuvable sur ce poste")
                      'Exit Sub
              If PathXML.Count = 0 Then
                  MsgBox("Aucune librairie de matériaux personnalisés n'a pu être trouvée")
                  Exit Function
              For Each fichier As String In PathXML
                  ReturnList.AddRange(ParseXMLTraitement(fichier))
              Next
              Return ReturnList
          End Function
          ''' <summary>
          ''' Lit chacun des fichier XML trouvés pour extraire les proprietes personnalisées
          ''' </summary>
          ''' <param name="PathXML"></param>
          Private Function ParseXMLTraitement(PathXML As String) As List(Of Classification)
              Dim Configuration As New System.Xml.XmlDocument
              Configuration.Load(New System.IO.StreamReader(PathXML))
              Dim ClassificationNode As System.Xml.XmlNode = Configuration.FirstChild.NextSibling.FirstChild.NextSibling
              While Not ClassificationNode Is Nothing
                  Dim newClassification As New Classification(ClassificationNode.Attributes("name").Value)
                  Dim MaterialNode As System.Xml.XmlNode = ClassificationNode.FirstChild
                  While Not MaterialNode Is Nothing
                      Dim newMaterial As New Material(MaterialNode.Attributes("name").Value)
                      Dim CustomNode As System.Xml.XmlNode = MaterialNode.SelectSingleNode("custom")
                      While Not CustomNode Is Nothing
                          Dim PropNode As System.Xml.XmlNode = CustomNode.FirstChild
                          While Not PropNode Is Nothing
                              newMaterial.CustomProperties.Add(New CustomProperty(PropNode.Attributes("name").Value, PropNode.Attributes("value").Value))
                              PropNode = PropNode.NextSibling
                          End While
                          CustomNode = CustomNode.NextSibling
                      End While
                      newClassification.Materials.Add(newMaterial)
                      MaterialNode = MaterialNode.NextSibling
                  End While
                  ReturnList.Add(newClassification)
                  ClassificationNode = ClassificationNode.NextSibling
              End While
              Return ReturnList
          End Function
      Ce message a été modifié par : Michael Corriveau-Cote
