I have been using a macro I found in this forum to export each sheet as a separate file. This macro is working fine but the "problem" we have when we are using this macro is that filename is generated as "filename - sheetname.extension" and for our needs we have to save the files as "sheetname - filename.extension". the reason behind this is that we have to place SAP code in front of everything to be visible.
I have tried to modify the macrto for our needs but I am amateur in programming and I can not find the line in code where I can change the order of the generated file name.
Can someone please tell me how can I modify this code? Also, can I implement custom property in this code?
code:
Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swExportPDFData As SldWorks.ExportPdfData
Dim swSheet As SldWorks.Sheet
Dim boolstatus As Boolean
Dim sFilename As String
Dim lErrors As Long
Dim lWarnings As Long
Dim strSheetName(20) As String
Dim varSheetName As Variant
Dim varSheetCount As Variant
Dim i As Long
Private Sub cboFileExt_Change()
Private Sub cmdSave_Click()
On Error GoTo error
Set swModel = swApp.ActiveDoc
Set swDraw = swApp.ActiveDoc
If swModel.gettype <> 3 Then
MsgBox "Open Document is not a Drawing file.", vbCritical, "Wrong Document Type Open"
Set swModelDocExt = swModel.Extension
Set swExportPDFData = swApp.GetExportFileData(1)
varSheetCount = swModel.GetSheetCount()
For i = 1 To varSheetCount
swDraw.SheetPrevious
Next i
For i = 0 To varSheetCount - 1
If i <> 0 Then
swDraw.SheetNext
Set swSheet = swDraw.GetCurrentSheet
strSheetName(i) = swSheet.GetName
Set swSheet = Nothing
varSheetName = strSheetName(i)
sFilename = swModel.GetTitle & "." & frmMain.cboFileExt.Text
If swExportPDFData Is Nothing Then MsgBox "Nothing"
boolstatus = swExportPDFData.SetSheets(swExportData_ExportSpecifiedSheets, varSheetName)
boolstatus = swModelDocExt.SaveAs(sFilename, 0, 0, swExportPDFData, lErrors, lWarnings)
Next i
Unload frmMain
Exit Sub
error:
MsgBox "An error has occured - Please close and reopen SolidWorks to try again", vbCritical, "Program Error"
Exit Sub
