My end goal is to take information from an assembly data card and put it into the body of a Word document.
I've got the variable mapping figured out in the Word data card; the text in the document updates when the Word data card info is changed. But, I'm not sure of a way to relate the Word doc with an assembly any more than just copy/paste as reference.
Is there another way to pull info from an assembly into a Word doc? Similar to how a .slddrw can pull info from a .sldprt or .sldasm.
Having it automatically update would be ideal, but I'd even settle for a manual method at this point.
EDIT: PDF attached as well
Hi Adam, you can use the Dispatch addin to accomplish this. Take a look at the attached dispatch action as an example, I think I have a PDF which i will try and attach as well which explains it better
Kind regards
Prasad Bhonsule
