Hello everybody,
I am trying to render a short 18 second animation in Photoview 360 in an assembly and everything in the model turns out as a white shiny finish. I can render a single image and it is fine, with correct plastics, rubbers and metals applied, but in the video every part of the model turns all white. Photoview 360 is installed and switched on.
The only thing that I notice is that when I right click on the model in the time line editor the drop down view doesn't give photoview as an option but i dont know if this is normal anyway.
You probably created the motion study, BEFORE you put all your appearances on. Appearances can be keyframed/animated as well so the state of the appearances when you create the first frame of the animation is what they will be for that motion study, unless you edit them at the first frame or some subsequent frame (which will animate them).
Assuming appearances are all correct when you have the "Model" tab active, right click on the motion study tab, then choose create new motion study, and then set up the animation. This way, the initial state of all appearances, should match what you now have in the norma Model view...and will remain the same unless you explicitly change them at a later keyframe.
