What decal making software (the artwork part) do you use and how hard is it to create your own custom decals?
Are any of these free for download or can be made online?
Kevin Andrews - I never use Decals, always drag and drop a jpeg right from File Explorer, onto either a profiled surface (split line curve or a flat face)
OK, maybe I wasn't clear enough....
I need to create a new decal/sticker/label that say: PULL - AUXILIARY PUSH - HYDRACHEM
Black background and white letters. Label size is approximately 1.5" wide x 1" tall
What program would you use to create a PNG image of this so that I can import, or drag-drop, onto the label base I will create?
Kevin Andrews - For any picture that's not available I would design and model everything in SolidWorks and then do a save as a high dpi jpeg, then drag and drop like I mentioned above...
