4 Replies Latest reply on Oct 29, 2018 10:50 AM by Dwight Livingston
    Reverse Path doesn't work for suppressed mates
    Dwight Livingston
      All
      Short version:
      I plan to put in an enhancement request for Reverse Path so it works for suppressing/unsuppressing mates, but I'm only on SW2016. Can someone with SW2018 check if this has been fixed already?
      Explanation:
      Most of the few motion studies I do go out and back, often with one part assigned a series of different tangent mates as it gets pushed this way and that, like a cam but more 3D. I manually unsuppress and suppress the mates as needed, by eye. This works fine.
      To do the process in reverse, I copy and paste all the time points, then flip them with the "reverse path" option. All the time-points flip nicely. All the changes to the distance mates flip nicely and run in reverse. However, the mate suppressions do not flip. It should work that each unsuppress becomes a suppress, and each suppress becomes an unsuppress. I have to go through and fix it manually.
      Can someone with SW2018 check this?
      Dwight
