VBA - Get component in assembly with broken or out of context references
Question asked by Cad Admin on Oct 11, 2018
I see by 2018 SOLIDWORKS API Help - Get External References (VBA) that i can retrieve the information for the feature level.
I just need to Traverse through and assembly and return the names of the component that have broken or out of context references.
i see by 2018 SOLIDWORKS API Help - swExternalReferenceStatus_e Enumeration im looking to only report on files with 0 or 4. but I'm my macro I'm getting a debug line for any line with a referencecount greater than 0...so basically any model with an external reference.
This is a pretty muddy macro(there are some unneeded things still around)...so
Option Explicit
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swModDocExt             As SldWorks.ModelDocExtension
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swFeat                  As SldWorks.Feature
    Dim vModelPathName          As Variant
    Dim vComponentPathName      As Variant
    Dim vFeature                As Variant
    Dim vDataType               As Variant
    Dim vStatus                 As Variant
    Dim vRefEntity              As Variant
    Dim vFeatComp               As Variant
    Dim nConfigOpt              As Long
    Dim sConfigName             As String
    Dim nRefCount               As Long
    Dim nSelType                As Long
    Dim i                       As Long
    Dim j                       As Long
    Dim swConfigMgr             As SldWorks.ConfigurationManager
    Dim vChildUComp             As Variant
    Dim swChildUComp            As SldWorks.Component2
    Dim swCompUConfig           As SldWorks.Configuration
    Dim sPadStr                 As String
    Dim CheckPromote            As Integer
    Dim CheckResults            As String
    Set swModel = swApp.ActiveDoc
    Set swModDocExt = swModel.Extension
    nSelType = swSelMgr.GetSelectedObjectType3(1, -1)
    For j = 0 To nLevel - 1
        sPadStr = sPadStr + "  "
    Next j
    vChildUComp = swComp.GetChildren
    For j = 0 To UBound(vChildUComp)
        Set swChildUComp = vChildUComp(j)
        TraverseComponent swChildUComp, nLevel + 1
            nRefCount = swChildUComp.ListExternalFileReferencesCount
            swChildUComp.ListExternalFileReferences2 vModelPathName, vComponentPathName, vFeature, vDataType, vStatus, vRefEntity, vFeatComp, nConfigOpt, sConfigName
        Set swModel = swChildUComp.GetModelDoc2
        If nRefCount > 0 Then
            Debug.Print "Model name: " + swChildUComp.GetPathName
            For i = 0 To nRefCount - 1
                If Str(vStatus(i)) = 0 Then
                    Debug.Print "    Out of Context Model path + name     : " + vModelPathName(i)
                    Debug.Print "    Out of Context Feature               : " + vFeature(i)
                    Debug.Print "    Out of Context Data type             : " + vDataType(i)
                    Debug.Print "    Out of Context Status                : " + Str(vStatus(i)) & " (Broken)"
                    Debug.Print "    Out of Context Reference entity      : " + vRefEntity(i)
                    Debug.Print " "
                If Str(vStatus(i)) = 4 Then
                    Debug.Print "    Out of Context Status                : " + Str(vStatus(i)) & " (Out of Context)"
                    Debug.Print " "
            Next i
    Next j
    Dim swAssy                  As SldWorks.AssemblyDoc
    Dim swConf                  As SldWorks.Configuration
    Dim swRootComp              As SldWorks.Component2
    Dim bRet                    As Boolean
    Dim Filename                As String
    Dim errors                  As Long
    Dim warnings                As Long
    If swModel Is Nothing Then
        MsgBox "Please open an Assembly file", vbExclamation, "No File Loaded"
        End
    If swModel.GetType = 1 Then '1 = part, 2 = assembly, 3 = drawing
        MsgBox "File is a Part, Please open an Assembly", vbExclamation, "File Mismatch"
        End
    If swModel.GetType = 3 Then '1 = part, 2 = assembly, 3 = drawing
        MsgBox "File is a Drawing, Please open an Assembly", vbExclamation, "File Mismatch"
        End
    Set swConf = swModel.GetActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    TraverseComponent swRootComp, 1
