What is relationship between the Occluded Undercut numbers (43) in the PM and numbers in the part? Because both do not match.
I've checked on SW 2018 SP 4.0 and I'm getting same results as Doug. So definitely issue with your installation OR it could be machine/SP specific.
I just ran the analysis on a computer that had an older graphics card with old graphics card drivers.
I got results similar to what Maha got (but not quite identical).
I then went to the Solidworks website to find out what the latest certified graphics card driver was for that exact system, downloaded & installed the latest driver, and fired up Solidworks & ran the analysis again. This time it gave the correct results.
Correction...it is certified/supported...
Go to here:
Graphics Card Drivers | Hardware & System Requirements | SOLIDWORKS
Enter your information and select the proper driver (18.20.24.03)
Download/install it using the link that Solidworks provides.
I went for clean installation now it is okay. But there is another problem. My Real View Graphics button is inactive. Do you any idea to fix it?
Radeon™ Software: How-To Clean Install - YouTube
I download the part from you post and ran the Undercut Analysis...did not get the same results as you did...
