I want to find the critical wind angle on an antenna.
I set up the project and the goals and I would like to find a way to run the simulation for different wind directions.
I know how to do it manually, but I am looking for a faster solution (rather than running 360 times)
Does anyone have any ideas?
Locate the assembly with an angle dimension.
In Flow use Parametric Study to iterate the angle dimension.
Don't run 360 iterations get creative on how to find the max force with the fewest computation time. May need a step process.
Log force on structure for each iteration.
More than likely the max force will be when the silhouette is at maximum area.
For wind velocity use formula below. If the antenna is small not to bother if large may be useful.
