Rob Jensen
Sketching a center line
Discussion created by Rob Jensen on Mar 9, 2009
When I use the S key or the caommand manager to sketch a center line, the icon doesn't update to a centerline. I have to pick it in the flyout menu, but the icon stillis solid.
Another issue is it wont' remember the last command. If you sketch a center rectangle it will stay as a center rectangle until you change it to something else. If you pick a center line and start sketching, then pick a circle (or whatever) and go back to the line toolbar it's back to solid lines.
Not sure if this is normal or what..?? Anyone else noticed this issue?
