Has anyone else seen this kind of mess while saving a Solidworks drawing to .DWG?
I've tried every tweak in the output settings and gutted the model of complicated parts, but it does this every time.
All these lines criss-crossing all over the views.
No surfaces at all. Just several fairly complicated views of a small machine.
All the diagonal lines that are shooing around the screen between views is the issue.
But I did find a solution just a half hour ago! We were saving the files out as R2000 format. Simply going back to saving as R14 format or below did the trick and the output is clean and correct.
I guess I need to admit that I DIDN'T try every tweak in the settings!
