All the files in blue are in my library.
What is a quick way to modify the references so the assembly looks in the library for the components?
Hi Douglas,
Assuming you are using PDM Standard/ Pro not WPDM, you should use PDM's "Update References" tool:
With the file checked out in explorer, go to Tools > Update References > Click the green folder "Find Files", normally clicking the root folder of the vault works for us, then Next > (Check the files are now all referencing the ones in the vault now) > Update. I usually find that afterwards, opening the top level assembly to check and then save makes sure that you get the right result. It's probably faster to actually do it than read how to do the process but it should fix all file references at once if they are already in the vault.
Hi Douglas,
