5 Replies Latest reply on Oct 9, 2018 10:32 AM by Jim Steinmeyer
    A size drawing prints larger than A size from SW but correctly when PDF.
    Jim Steinmeyer
      A couple of weeks ago I worked to update our drawing templates. Today I created a new drawing with the new A sized template. First the dimensions were formated as stacked fractions where I had saved them as 1-1/2". Not sure why they saved that way. But a bigger issue is that when I went to print the drawing to verify I had the dimensions correct, the sheet was scaled up. The borders were off the page and the 3-3/32" dimension measured closer to 3-1/2". I tried this on both an epson and a cannon printer with the same results. I then created a pdf of the drawing and everything was correct. I have searched the sheet options as well as the print options and can find nothing to control this. Does anyone have any suggestions?
      The model and drawing are attached.
