The artwork is circular, it has a transparent background from a square art board. When I import into SW, the image is a square. How do I either make the make the .jpeg round or get the back ground to shown transparent? I have attempted all of the transparency settings and none of them will drop the "background" out.
Hi Kevin, JPEG's don't support alpha channels so even if you created the graphic in illustrator with a transparent background it's going to come in white.
JPEG's also a lossy compression which produces image artifcats.
Instead of JPEG, export your graphics to PNG and enable background transparency.
When inserting the image into your sketch set the transparency to 'From file"
