I am using Solidworks 2015 SP5.0 on a Windows 7 enterprise. It is crashing so often its becoming unusable. I don't have a subscription currently.
Is there a better service pack? Can I get it without a sub? Recommendations?
Personally, I would do a reinstall. In fact, I might even reformat your drive and reinstall Windows fresh. Lots of things can happen that forschimmel your installation. You could spend a week and be a hero and figure out what it was, or you could just reinstall. Bad install, bad uninstall, driver conflict, bad sector on drive, bad memory, it could be a lot of things. Consider a fresh install. Especially if this is an old machine that has never been reformatted.
I will work on getting a sub.
I don't have admin rights and getting IT support is almost as hard as buying new software
You might need a new computer for newer version of SW.
A new version of SW cannot fix old hardware problems.
Or old Windows problems.
This is why I avoid upgrading to new versions. The overall experience is almost always worse on newer versions because of resource issues.
Is 2018 worse than usual? Do you think the jump from 2015 to 2017 would be bad?
For now I will deal with the issues in 2015 and then I will upgrade when my machine gets lifecycled.
No better service pack. There are better versions which you cannot get without a sub.
I recommend sub.
