Re: Toolbox holes
Matt Peneguy Oct 3, 2018 5:49 PM (in response to Jim Clark)I am interested in this, too. You can make a custom size, but I'd rather have larger ones available. I'd like to see up to at least 3". I care a lot less about the fasteners, but I'd like to see it in the hole wizard.
I'd also like to see larger sizes for the fits. ANSI B4.1 goes all the way up to 200 inches. But, SW only goes up to 19 inches (at least for H7). But, I guess I'm in the minority on that.
Re: Toolbox holes
Rubén Rodolfo Balderrama Oct 3, 2018 8:16 PM (in response to Jim Clark)Did you tried to add your custom values?
Re: Toolbox holes
Cad Admin Oct 4, 2018 6:06 AM (in response to Jim Clark)Create custom(larger) sizes in the toolbox by customizing it(if you have access/rights)
in your SolidWorks program folder, select > SOLIDWORKS tools> Toolbox Settings ....Select HoleWizard.
Add/edit the tables...
Or Inside SolidWorks...Select Options> System Options> Hole Wizard\Toolbox> Configure ....same result location as above.
Re: Toolbox holes
Bjorn Hulman Oct 4, 2018 6:26 AM (in response to Cad Admin)Agreed, Here's a video I've found very informative in the past. Configuring the SolidWorks Toolbox - YouTube
Re: Toolbox holes
Cad Admin Oct 4, 2018 8:32 AM (in response to Matt Peneguy)I upgrade my toolbox, I've never lost any customization...But the Import/Export is a good Backup
Re: Toolbox holes
Matt Peneguy Oct 4, 2018 8:34 AM (in response to Cad Admin)I did not know that! I guess that's what you get when you assume... I am going to have to look into that. Thank you!
Re: Toolbox holes
Bjorn Hulman Oct 4, 2018 8:49 AM (in response to Cad Admin)Import/Export is a great way to add bulk custom properties as well.
