Marco Crociani
How to write properties in the cut list of multibody-part
Discussion created by Marco Crociani on Oct 4, 2018
Latest reply on Oct 17, 2018 by Deepak Gupta
Hello everyone,
i use a multibody-part with SW2017 sp5, I have this macro that works perfectly to write some properties in the cut list:
the macro recognizes that the body was made with "metal-sheet function" and writes properties in the cut-list only in "metal-sheet" bodies.
I would have this further improvement,:
when it recognizes the first sheet-metal body I want to define a progressive number "1" and use it in the properties of the cutting list of this body
when it recognizes the second sheet-metal body I want to define a progressive number "2" and use it in the properties of the cutting list of this body
when it recognizes the third sheet-metal body I want to define a progressive number "3" and use it in the properties of the cutting list of this body
can you help me????????
look below my macro
Thanks in advance
Option Explicit
    Dim swApp               As SldWorks.SldWorks
    Dim vBodies             As Variant
    Dim swmodel             As SldWorks.ModelDoc2
    Dim swFeat              As SldWorks.Feature
    Dim swCustPropMgr       As SldWorks.CustomPropertyManager
    Dim FileNumber          As String
    Dim FileName            As String
    Dim Codice_1            As String
    Dim CODICE              As String
    Dim CODICE_FINALE       As String
    Dim UM                  As String
    Dim PESO                As String
    Dim DESCRIZIONE         As String
    Dim TIPO_LAM_1          As String
    Dim TIPO_LAM_2          As String
    Dim sThickness          As String
    Dim Folds               As String
    Dim swBodyFolder        As SldWorks.BodyFolder
    Dim j                   As Integer
    Dim swBody              As Body2
    On Error Resume Next
    Set swmodel = swApp.ActiveDoc
    Set swCustPropMgr = swmodel.Extension.CustomPropertyManager("")
    swCustPropMgr.Get4 "CODICE", False, CODICE, """"
    swCustPropMgr.Get4 "CODICE_FINALE", False, CODICE_FINALE, """"
    swCustPropMgr.Get4 "UM", False, UM, ""
    swCustPropMgr.Get4 "PESO", False, PESO, ""
    swCustPropMgr.Get4 "DESCRIZIONE", False, DESCRIZIONE, """"
    swCustPropMgr.Get4 "TIPO_LAM_1", False, TIPO_LAM_1, """"
    swCustPropMgr.Get4 "TIPO_LAM_2", False, TIPO_LAM_2, """"
   'search the file name
    FileName = swmodel.GetTitle
    Debug.Print "Nome File --> "; FileName
    'delete the file extension
    Codice_1 = Left(FileName, InStrRev(swmodel.GetTitle, ".") - 1)
    Debug.Print "Codice_1 --> "; Codice_1
    Set swFeat = swmodel.FirstFeature
        Do While Not swFeat Is Nothing
        Debug.Print "NAME: " & swFeat.Name & "   - TYPE: " & swFeat.GetTypeName
        swFeat.GetSpecificFeature2
            If swFeat.GetTypeName() = "CutListFolder" Then
            Set swBodyFolder = swFeat.GetSpecificFeature2
        'Debug.Print swFeat.GetTypeName
            vBodies = swBodyFolder.GetBodies
             For j = 0 To UBound(vBodies)
                Set swBody = vBodies(j)
               'if he finds a sheet-metal he writes "SHEET METAL !!!! -> N." & progressive number
                If swBody.IsSheetMetal Then Debug.Print "SHEET METAL!!!! --> N." progressive number
                If swBody.IsSheetMetal = False Then GoTo salta
             Next j
           ' here the macro write the properties in the cut-list
            swBodyFolder.UpdateCutList
                        Set swCustPropMgr = swFeat.CustomPropertyManager
                        swCustPropMgr.Get4 "Spessore lamiera", False, "", sThickness
                        swCustPropMgr.Add3 "CODICE", swCustomInfoText, Codice_1 & "." & progressive number, 1
                        swCustPropMgr.Add3 "CODICE_FINALE", swCustomInfoText, Codice_1 & "." & progressive number, 1
                        swCustPropMgr.Add3 "UM", swCustomInfoText, "NR", 1
                        swCustPropMgr.Add3 "PESO", swCustomInfoText, Chr(34) & "SW-MASS" & Chr(34), 1
                        swCustPropMgr.Add3 "DESCRIZIONE", swCustomInfoText, "Lamiera sp. " & sThickness & "mm", 1
                        swCustPropMgr.Add3 "TIPO_LAM_2", swCustomInfoText, "sp. " & sThickness & "mm", 1
                        swCustPropMgr.Get4 "Piegature", False, "", Folds
                        If Folds = 0 Then
                        swCustPropMgr.Add3 "TIPO_LAM_1", swCustomInfoText, "PIANA", 1
                            Else
                            swCustPropMgr.Add3 "TIPO_LAM_1", swCustomInfoText, "PIEGATA", 1
salta:
        Set swFeat = swFeat.GetNextFeature
        Loop
