weldment cutlist table
lenght remove zero
how to
Arif
This method does not remove numbers larger than zero.
"Document properties>Tables>Weld, Set Training Zeros to Remove"
This method hides all the numbers after the point.
for all sizes. If you add a size measure in the technical illustration, the number will not be after the point.
"Document properties>Units, and change Length decimal places to None."
Which method did you choose?
If you want to Remove Training Zeros...
if you want to change precision...
**But as previously stated this is for the whole drawing
