Re: Unable to link data card to drawing
Mohamed El Orche Oct 2, 2018 4:36 PM (in response to Sagar Patil)Hi Sagar,
Off the top of my head, Could you try disabling The "Updates all configurations" flag on your data card?
When it's enabled, the variable gets updated with the same value in all configuration tabs.
Make sure all your modifications are saved in the Admin tool.Mohamed
Sagar Patil Oct 2, 2018 4:48 PM (in response to Mohamed El Orche)Hello Mohamed,
I have already tried that. Un-checking "Updates all configurations" does not seem to solve the issue.
Mohamed El Orche Oct 2, 2018 4:52 PM (in response to Sagar Patil)Hi Sagar,
Let's see what happens if you check out those guys and check them back in?
Mohamed
Sagar Patil Oct 2, 2018 4:54 PM (in response to Mohamed El Orche)-
Mohamed El Orche Oct 2, 2018 6:56 PM (in response to Sagar Patil)Hi Sagar,
This is expected behavior.
Parts and assemblies have custom and config specific prop whereas drawings have only custom prop.
If you use PDM 2018 or older, you need to use the API (see S-047019) to get values synchronized between a drawing's @ tab and its sheet tabs. However, PDM 2019 allows you to do an automatic update of $PRPSHEET variables on the tabs for all sheets (not only @ tab). It's one of the new functionalities actually.
I suggest you run this by your VAR. They will help you find a workaround.Hope this helps
Mohamed.
Sagar Patil Oct 3, 2018 9:41 AM (in response to Mohamed El Orche)Thanks for the help. I will play with the API.
