Hi
My company don't use Toolbox, we have custom toolbox. But Toolbox folder ("C:\SolidWorks Data") is needed for holes.
I want to distribute my unique solidworks configuration file (sldreg) to all machines. But every machine has a different folder, like:
- SolidWorks Data
- SolidWorks Data (2)
My configurantion use:
- SolidWorks Data 2013
When user start SolidWorks, he ask user to which toolbox folder want to use and the default answer (yes) is bad !
There is a method to set correctly from sldreg or without asking the toolbox folder ?
Tnx, BuDuS.
I thought maybe leaving the line in the config file blank might trigger SolidWorks to not change that value.
But instead it gives an error on launch and then this one when I try to go to the Toolbox tab in options
When I just created the options file I had the toolbox location set to a folder in the SWPDM vault, so it must have deleted that location out completely.
Yep, once I got it to actually go to the toolbox tab it was empty.
Sorry, that wasn't much help. But I will leave it here as an example of what won't work.
