I have been using SW Flow for about 3 months for my thesis. I am wondering if there is a way to input residual value like other softwares e.g ANSYS for convergence using for validation.
It would be appreciated for any input.
Thank you
Thank you
Hi Will,
You can't input a dimensionless numerical residual, but we can still manually override the convergence tolerance using the convergence criteria value or percentage which is effectively the same thing.
If you have a study setup you can go to Tools > Flow Simulation > Calculation control options.
For the particular goal in question you can set the goal criteria to manual and specify a convergence value (with units) or percentage (default is 3% delta).
The help button will take you to more useful information about the convergence delta criterion values mentioned above so that's the best place to start first!
I hope that helps.
Sameer
