Hello!
I am modeling a full sized part and want to scale it down 1/8. I made the part using full size drawings, auto-created a design table, made a row, and divided each column by 8. This generated a new configuration which... only changed a portion of the dimensions.
I am new to using design tables, so I'm not sure what the limitations are. Am I not selecting the dimensions properly? A few of the dimensions I wrote in as Feet plus Inches, but they display as just inches. Could this be screwing me up? Screenshots and part file attached.
Hey Guys,
Correct answer is operator error, haha. D7 is an angle; 45 degrees. Scale the angle, and it goes haywire. I adjusted it to stay at 45, and now I have no problems.
I tried to make the scale feature work before, but it does not scale dimensions, and the end result is to have a drawing to make the part from. If the design table didn't work, I'd have to simply make a new part and hand-jam the numbers.
Thanks anyways. This did help. I didn't know that it reconstructed the sketches by column. In this case I'll start constructing sketches in such a way that I won't end up with zero length lines or otherwise.
Matt
