Dear Friends,
I don't now if I have to post this in Solidworks forums.
I am an intermediate Design Engineer (You can consider me a fresh entry as well that doesn't matter)
My guess is
1)pressure drop at the inlet may not go well with a pneumatic system.
2)Lubricated air , if regulated at the entry to cylinder may rise temperature of the system
3)or it may rise upstream pressure and we may need extra bleed off valve at the entry
But I don,t want to rely on guessing
Can anybody who is regularly into pneumatic design can help me with this basic doubt
Regards,
Nikhil
Thanks in advance
I was always told to use the meter out on pneumatics because that prevents a jerky motion of the cylinder as the pressure builds up in the flow control valve till it lets the air thru into the cylinder. With a metering out, you have a constant flow of air pressure into the cylinder preventing the jerky type motion that's usually unacceptable with cylinders.
